I bought these to overhaul the front brakes on my 2019 R1250GSA but I have now sold the bike hence I have them for sale.
For compatibility with other models see the links below
EBC MD687 Stainless Front Brake Discs https://ebcbrakesdirect.com/ebc-ssteel-solid-disc-20-md687
EBC FA724HH Brakes Double-H Sintered Pads https://ebcbrakesdirect.com/double-h-sintered-street-pad-fa724hh
Included are Brembo Serie Ora bobbins for 5mm discs which were purchased from SP Engineering, these allow you to avoid having to buy the expensive genuine BMW discs with non-removable bobbins and they can be re-used when it comes to replace the discs again in the future, you can't normally buy these separately but SP engineering kindly split a Brembo brake disc kit for me and let me buy them separately.
Also 10 x new Genuine BMW rotor bolts, these bolts are single use so you shouldn't re-use your old ones when fitting new discs.
I will also include a bonus new front ABS sensor ring worth at least £50, really worth having one of these because at some point it'll get bent when you get your front tyre changed.....
All as new and un-used
£250 + P&P
£250 + P&P
