ECU Heat
Delboy777
In a Remote area apparently.
How hot does the ECU on a 1250 get under normal conditions. Reason for asking is im thinking of fixing my Innovv K2 DVR in the space mounted with 3m dual loc tape. Would there be a problem doing this ? Del
I have my innovv K2 on top of the ECU - no problems - secured with 1mm double sided tape
Thanks for that. My one is in the rear compartment beside the TPS unit. However with the ezCan in there too, albeit tucked down one side there is precious little room and the seat unit might damage it. Thinking i will move it but then i will have to move the converter because its not supposed to be anywhere near the DVR unt.
leave it where it is but lose that bundle of cables under the silver trim,theres plenty of room to the rear.
