Electrical connector Blocks
Jimwoodall
Peel
Hi
Trying to unclip the wiring from accessory left hand fog light (you know why!!!!). What's the correct way to release it from the socket ?
Jim
Hi
Jim
Insert a thin blade screw driver into the hole at the front feel for the clip / release tab then pull connector off. Yes I know why bloody things are useless
Terry
Thanks Terry.
Hair dryer got them working again. Going to try some marine grease I think when I pull off the connector
Thanks Terry.
I used ACF50 which seems to work, my worry is all the other connectors on the bike are similar, what's next?
Also my last lamp failure was due to water ingress into the light unit it's self, there was a pool of water behind the lense.
Good luck Terry
Cheers. I've been lucky to own many many bikes over the years. Last 3 were new beemers (xr,rr and this one) and all three have needed warranty claims (grips, broken panels, lights respectively). Mind you, I do like everything else about my GSA so will have to find a workaround for the lights. Maybe move to Arizona!!!! Suns out so going to play and get her dirty again so I can wash it and see what else stops working afterwards ��
