Hi,
I am no expert and googling around or looking at suspension manufacturers sites will get more detailed results, my basic understanding is:
Shock Types:
1. Emulsion shocks are cheap and nasty, just a plunger in oil, the oil tends to froth (cavitate) easily in these shocks and they can overheat and fade quickly.
2. Most other shocks are Gas Shocks, these use a compressed gas to stop the oil from frothing up, the oil and gas is seperated by a piston, there are several variations:
a. Internal gas reservoir - gas in shock body,
b. Piggy back reservoir - Gas is held in a reservoir attached to back of shock body
c. Remote reservoir - The reservoir is attached to a hose
Theoretically remote is the best as the unit is likely to be in a better cooled area, but some top end units are also piggy back style, the internal reservoir types are normally at the lower end of the Gas Shock market.
The gas also provides some springing action, this is non linear as the springing effect is due to compression of gas as shock compresses and is exponential so these shock may have different spring rates to emulsion type shocks, or even other shocks with different gas pressures.
The gas does slowly leak over time and they can need re-gassing, however this is 2-3 years and 20-30k miles on most units. The gas pressure can also be used as part of fine tuning the setup.
Spings:
The experts do not seem to agree on progressive Vs linear springs, I expect some bikes are better suited to one tyoe than the other, in theory progressive are good for the road as it is varied environment and linear is great for the track. The problem is as you alter spring rate you need to change damping to suit, as progressive springs have a varying spring rate it is impossible to accurately tune the damping to suit leaving it underdamped at one end of the stroke and overdamped at the other - I have no idea if this is a big issue and maybe progressive spring suit the GS very well, perhaps they don't - maybe go to an expert with experience of GS motorcyles and ask them, or look at what Ohlins do as they are really the world leaders in suspension.
Manufacturers and Quality:
Every shock manufacturer makes great claims, but they can vary wildly in cost and performance:
At the low end units may not be rebuildable and some probably are no better than OEM (but probably a lot cheaper if your just looking to replace a duff unit)
OEM (and I would guess cheaper) units can vary a lot from bike to bike, I know if you take several standard bikes and check the shock gas pressures they can vary wildly - I assume oil levels may also not be finely controlled either, and for this reason it is often pointless taking other peoples suspension settings and expecting same results on your bike.
More expensive units should have better QC and be rebuildable so after 20-30k and for about £100 you should be able to have the unit serviced and it will be good as new again.
More expensive shocks will probably have more adjustments (I always prefer two way adjustment and remote pre-load adjustment) and high end units such as Ohlins have features such as temperature compensation to keep the damping consistent as the shock get hotter. Having said that a £800 shock with 2 way adjustment is probably better than a £500 shock with 3-way adjustment.
My bike is booked into MCT suspension in the UK later in the year, I trust their recomendations and advice due to excellent work on my last bike and friends bikes and they tell me on the GS the Ohlins kit is excellent. They also say the Wilburs is good, but not as good (or expensive) as the Ohlins.
I see many familiar names in your list, but only have personal experience with ohlins and modified OEM units. Ask around and see if you can find people who have used the other stuff, I expect most of it will outperform the OEM kit and as a rule of thumb you get what you pay for (most of the time) and very rarely get more than you pay for.
I know the Wilburs kit is "modular" so you can decide if you want 1,2 or 3 way damping, or if a remote pre-load adjuster is required. Ohlins offer 2 types of rear shock and 1 front for the standard GS + short options (for lowering the bike)
MCT also tell me they cannot do much with stock GS units so you really have to replace the units if you want to improve the suspension. I was lucky on my last bike as they could re-spring and re-valve front and back of the bike for about £500 - I think the GS is gonna cost me 2-3 times that amount!
