END FLOAT
big albig
swansea wales
Hi Can anyone help me please, Heard about the END FLOAT adjustment
can anyone enlightn me, and does it have to be done while your having your
tappets adjusted.
Big al
1100GS
The end play is measured with a feeler gauge placed between the rocker arm and the end cap. You do this whilst holding up the rocker arm and placing the feeler gauge in-between the two parts at the bottom.
Steptoes Thread in the font of all wisdom has a picture for you... :rolleyes:
you measure and adjust both rocker shaft gaps on each Cylinder, Inlet and exhaust side. At the bottom. Thats four places to check and recheck, ........ and dont forget to match your valve clearances...:eek:
and then you will need to do a throttle balance ....:thedummy
