Engine corrosion repaint.
NeilGS
Staffs
A friend of mine has a 2019 R1250GSA having done 25000 miles. The engine paint is suffering corrosion as per picture but as he bought it out 3 year warranty I assume BMW would not be interested in doing anything for him.
Has anyone done a DIY rub down and repaint? How has it turned out?
I’d tell your “friend” to gently remove corrosion with red Scotch Brite pad, apply ACF50 with a paintbrush, (mostly to conceal) and trade the fucker in on new shiny one.
BMW approved used warranty does not cover this, as I found out much to my annoyance. Imagine how many times a year each BMW dealership tells unsuspecting customers this fact, each dealer must break the news dozens of times a year.
It still rankles with me to this day that the premium brand does this. I sold the LC shortly after and now have an r1150, it has a little corrosion but as it's over 20 years old and was a fraction of the price, I am fine with it.
All my bikes have received a regular spray of ACF or similar product regardless of manufacturer.
You can’t expect an exposed lump of metal to withstand salt spray and stone chips forever without a little help.
I did it all, I treated my 1200lc like a baby, I think that's why it was such a blow to be left in the cold by BMW. It's not lack of care or protectant that leads to engine paint corrosion
Same here, a little care goes a long way, the bare, brushed aluminum cases on my 13,000 mile 2017 Thruxton R are almost as new because of a frequent wipe over with ACF 50 or similar product.
So has anyone managed to do a decent job in ‘repairing’ the areas of corrosion?
I suspect that the answer is no - I'm sure you could clean and sand down the affected area and give it a re-spray from a can or brush on some paint as a way to stop the 'rot' spreading, but the only way to get a really good finish would be to have the individual parts removed and professionally re-finished - but I have never tried it, so I could be talking bollox :)
I sorted the corrosion on a 1200 I owned, taking it from this
To this
It took a fair bit of elbow grease mind you
  • Like
Reactions: Red
Mine were replaced by BMW under warranty two months before the end of the three years but I had planned to remove all the loose stuff and use Hammerite smooth. IMHO if you can't do it properly by removing the bits and getting them treated and sprayed professionally, or can't afford it etc. then you might as well use something that will definitely work and you can forget. I think if you spend care on the preparation you should be able to get a half decent finish and it's very tough. Sometimes, you can only do your best.
