Engine paint/corrosion
Zog
Member
Watford, England
Hi All, I bought a 2010 GS yesterday, with 23k on the clock. There are small patches of corrosion & paint peeling from the engine & cylinders, which I'd like to correct. What is the best way and what paints/hammerite etc should I use? Or can this be done professionally, cheaply? Thanks in advance.
Hammerite is probably best for small to children ups. But it's not chip resistant so less good for the cam gears cover where it gets road rash.
Mine never had a fender extender so my front cover has a 50p coin sized patch where paint is missing. For now, I have peeled of the loose paint to keep corrosion from creeping further and treated with ACF-50. The only long term solution is powder coat. As a good match is impossible I will probably get it done in black and paint over.
While the bike is laid up I will probably get crash bars stands and anything else done at the same time.
Hammerite silver is not a bad match, a long as you get the smooth not hammered effect:D
I just did a few parts on mine with Hammerite Silver Smooth...as others have said - it's a pretty close match but not perfect. You will notice the difference but others generally won't unless you point it out to them.
This question arises with monotonous regularity, must be something amiss with BMW paint finishes ;)
My vote is for paint / etch primer, found it durable enough but nothing lasts forever and fork legs timing chests ect need freshening up after 4/5 years, depends what your riding through I guess.
Recommend Simoniz Tough Black Satin, with an etch primer on your engine (Assuming its black) most of the silver wheel paints are close enough for silver engines and forks.
Did a write up here some time ago, the work lasted well as you will see if you check out the later posts; (23000 views!)
http://www.ukgser.com/forums/showthread.php?t=136102
The engine paint on mine is solid except where stones have battered it.
Once corrosion sets in under the finish lots of damage can be done before its obviously a problem. Tougher finishes like powder coat are great but they can hide a lot of problems with little chips letting the weather in.
Hi Guys, thanks very much for the advice, I'll get some hammerite shortly.:clap
