russell
Thinking about getting a f750GS. There's the standard manual adjust rear suspension (which should do me) and there's the ESA ( which gives you solo, solo with luggage or two up)with electronic adjustment for hundreds of pounds. I ride solo so there won't be any changes once it's set up. My question is apart from how you adjust the set up is there any difference in the ride between the two options.
