Ravenbyrne
In the process of fitting a Scottoiler eSystem to Spear Rulers 650 Twin.
Wired the negative wire to the - volts battery terminal and spliced the positive to +12 volts at back of the power supply socket on the tank.
Switch on the ignition and the eScottoiler display lights up, but when I press the start button and run the engine the display goes out about 10 seconds later. It is designed to stay on.
What have I done wrong.
Cheers,
Brian
Cheers,
Brian
