etrex....using co-ordinates?
  • Thread starter Thread starter bryan
bryan
Hi,
i've recently got an etrex,.....useful bit of kit ,
but can you put co-ordinates in and then use the goto function?
thanks bryan
bryan said:
P hil,
do you need to downlloaded them via a computer?
No you can do it on the unit itslef though it is a bit tedious. I have (had I should say, the old man has it now) an Etrex Summit and am not sure of the model you have ? I presume they are all the same in "how to do it". Basically mark a Waypoint and then "edit" the co-ordinates. See the section in your manual about marking a waypoint and further on in the same section should be instructions to edit the co-ords.
Download the manual from the Garmin web site if you have misplaced your's.
Best 'o luck !
