Sold Evo tech satnav mount ( Tom Tom )
stever1
Elderly n deluded I’m told.
Back in Hull
NT1100 sat nav mount, bought in May, I’m changing to a Garmin so I’ve had to change the mount.
£30 posted to uk mainland. 👍
Could this be ‘adapted’ to fit on top of a brake master cylinder ?
Erm……I don’t know actually. If you look on the link there is an option to open the instructions. Perhaps that may help you.
BTW, what bike ?
BTW, what bike ?
It’s a Burgman 650. Handlebar shrouds, no exposed fittings to piggyback onto, no mirror stems, nothing that suggests itself other than the two bolts on top of the brake master cylinders. I was thinking along the lines of re-drilling one side of this so the two holes aligned at the top of the cap.
Can I ask please what is the measurement between the two mounting bolts on this ?
The hole centres are about 100mm, it looks like it could be drilled for a shorter distance, down to about 70mm. I’ve attached pictures so you can see it in more detail. 👍
