Exhaust studs.
milleplod
Bolsover, no longer the home of the Beast.
Just fitted new suspension to my '06 RT, so all the plastics are now off and I'm fettling! I've taken the headers and silencer off - the nuts came off very easily - I've got some brass ones to go back on - but the studs themselves are quite manky. Sherlocks do stainless replacements. What do you reckon - just clean up the studs with my dremel, or remove and replace? Do the 1200 studs have a tendency to seize like the earlier bikes?
Pete
Pete
Clean them up with brass wire brush in dremel then anti-seize paste. Unless they are obviously corroded in which case replace.
Sent from my SM-G925F using Tapatalk
Use a brass wire brush; then run a die nut down the thread to make sure they're ok.
Then replace nuts. I prefer the old Honda style domed nuts, filled with anti seize paste.
Pete, I can send you some aero spec neverseeze, if it's good enough for gas turbines it's fine for BMW's, I use it all the time on all my vehicles. PM me.
Al.
The OEM closed end nuts have been fine on mine. The very worst exhaust nuts were on a Yamaha. They were drilled right through with a hex socket on one end. The hole through was perfect for making sure they seized up. I got them out by arc welding the nuts. The sharp focussed heat also shifted the studs from the head so they were replaced.
They were replaced with Action Can CS90 High temperature high solids anti seize paste. I used stainless dome nuts (which should quickly erode the stud's zinc plating) but never had another problem with those exhaust studs.
If you choose the arc welding option, disconnect the alternator and ECU connectors. They "should" all be fine but a few weeks after doing my Yammie exhaust studs, the battery was boiled dry by a failed alternator regulator. Coincidence?
