Hi, if you do another batch of these, please can you add my name to the list as well? Ta.
Can I just say, at the risk of being proved wrong and being abused of course!! I bought one of Gordon T's eliminator tubes and yes it worked perfectly with standard Headers and can, but I found it too short to work with aftermarket ( remus in my case) headers and link pipe, this was due to the the cut outs in the exhaust, when I fitted the link tube it didn't cover the cut outs all the way about 10 mm short, which allowed exhaust gas to escape through the clamps. I put in a 78mm tube and problem fixed.
Does seem odd as the OE BMW valve has apparently been measured at 67mm long according to an earlier post. Surely the aftermarket pipes would be even worse in that case?
I understand what your saying Raymondo, I even refitted the BMW valve between the remus headers and link pipe and it was too short!! I checked all the fittings on the headers, they were correct and used all the adjustment on the can to try and make it fit, whatever I did it was too short. I wish I'd taken some pictures now to help explain.![]()
Surely a problem with the Remus pipes then, rather than the eliminator tube..?
