Exporting favourites from MRA into BaseCamp
Berin
South Oxfordshire
I'm route planning! Hence all the questions
I've created a long list of favourites in MRA, which I'd like to import to Basecamp. Anyone found a way to export favourites from MRA?
From the MyRoute forum:
Thanks, I did try that. I'm trying to import them into basecamp. I exported the route with all the favourites as a gps, then imported to Basecamp, but no waypoints come across. I also tried various other things, such as exporting the route with the favourites in as a csv, then reimporting them to MRA as POI's then exporting that as a gpu, but it doesn't seem to work.
MRA do say they are working on better use of waypoints/favourites
If you Create a route of your favourites and save it as a KML before importing it into basecamp the waypoints will come into basecamp separate from the track . At least they did on my PC. You can then delete the track and be left with the waypoints. But you need to make sure you convert them all to Via points before you save as a KML
Nope basecamp will import KML on a Windows PC, not sure about mac. Make a map route in MRA with all your favourites on it export it as a kml and it will import the favourites separate to the route. Just make sure that all the Favourites are (Hand) via points in Myroute app before you export them. You can then separate the Waypoints in Basecamp and send them to others as a GPX. IF you send them as a GPX from MRA to Basecamp the Waypoints are embedded in the route for some reason.
A very late reply, but yes, Basecamp will import KML files with waypoints on a MacBook, just transferring my MRA 'Favorites' (blooming Dutch American English) into Basecamp to transfer to the XT, what a faff.
