There is a special relay which feeds the ignition- it does not show up on the diagnostic but it can and does fail.
It is the large cube 7 pin iten , either orange or green , which you can see down the front of the battery , under the cover. It has a capacator to feed the BMS unit 12 volts for 3 secs, and a diode to make certain the current only goes one way.
Substitution is the only check although if the part number has been blanked off in texta it is a good indication that it from the old dud stock that have been lying around since the days of the first K bikes and BMW ere trying to slip out 24 tears later. Dont ask----.
