Mouse
I was doing some fettling on Clare's F650 and found that the air filter (only fitted a few weeks ago by myself) has got oil on the lower two "flaps". I then checked the drain tube from the airbox and there was maybe 10ml of oil in there, which I drained out.
What could cause this, and is it a problem? I'm pretty sure the oil hasn't been overfilled (I keep it about half way up the window), and even if it was slightly, surely the design of the system, with the seperate oil tank, would mean the excess would be in the tank, rather than in the crankcase?
Any ideas?
Any ideas?
