- Joined
- Jan 3, 2002
- Messages
- 1,487
- Reaction score
- 8
2000 bike, everything seems OK, no slack or obvious bearing wear, spacer (on disc side) in place, cush is a bit sloppy (not tweaked with inner tube bits etc as yet), axle rotates smoothly is greased and slides in an out (oh err) lovely, chain not too tight. Pads OK and pushed back out of way, alighment correct both sides
All spins with axle loose.
Tighten axle and it seems like some resistance - but can't fathom it.
Any clues? Got me stuck, and it's failed MOT so need a solution (would need one anyway)
I'm assuming the sloppy Cush isn't the issue - but could it be related?
Thinking about it, the one thing I didn't try
was tighting axle with chain off, but can't see that being the issue, it's consistant once wheel spun with axle tight.
No centre stand so it's a PITA mucking about with it all
Any suggestions welcome
was tighting axle with chain off, but can't see that being the issue, it's consistant once wheel spun with axle tight.No centre stand so it's a PITA mucking about with it all
spot on
they never went on the R80 or R100GS...yet
(to a blind man!) but didn't turn at all and was also dry and shagged
