F750/850/800/900GS Steering Head Nut Tool
RadioFlyer
British Columbia, Canada
If anyone has (or has made) the socket (or the special BMW adapter) used to install/torque the "grooved nuts" on the steering stem would they please post the dimensions (outside diameter, inside diameter, tooth width and height)? Thank you.
I would like to make one.
You can just tap it loose using a hammer and a brass drift or if you want the proper tool measure the size of the nut and google “castle nut socket” and match the size
I think this may be the thing you are after :
