F800GS 2010 - front brakes, double banjo bolt - how many crush washers
bobbsy
Kent, England
Hi all,
Wondered if anyone could help please.
I removed the front calipers to rebuild, and now as I prepare to reassemble I cannot remember the crush washer arrangement on the double banjo bolt on the left caliper, where the double bolt connects both the line down from the master cylinder, and the extension line that goes across to the right caliper.
Does it use 2x crush washers (i.e. no washer at the mating of the two brake line fittings), or 3 crush washers (with one in between the two brake line fittings)? I have two washers retained on the bolt from disassembly, but worried I may have dropped/lost a third without noticing.
Many thanks
B
