F800GS front sprocket assembly
ymfb
Salisbury
Would someone kindly post up an exploded view of this area. Since I changed the chain and sprockets there has I think been a marked increase in vibration at higher speeds. Last night whilst fettling I found a large diameter slightly shaped washer and am suspicious it could have come from that job.
Hello, yeah that washer should be between the sprocket and the bolt, put it back on :blast
The washer between the head of the bolt and sprocket can be seen here
The washer I have found is 35 od x 16 id and is slightly dished
Any chance you have fitted a non-BMW front sprocket and what you are holding is the backing off the OE version which is the anti-vibration backing ?
The new front sprocket was from Touratech. Should I have fitted this as well ?
