F800GSA Clutch problem , help /advice ?
Not open for further replies.
Richie B
Devon
Hi all I've noticed my F800GSA is getting very hot when slow riding or on idle , its about 83/86deg when moving going up to 106/108deg when stopped or very slow moving. When at high temp its impossible to select neutral, also very hard to change gear. any advice out there or has anyone else had the same problem ?
cheers Richie
Yeah it is, do you know what temp it should start and stop at ?
Cable correct, oil levels fine , no leaks
You didn't do a service recently? I mean changing the coolant. Airlocks in these systems are not unheard of...
Thanks for all replies, the bike went into BMW today and they have discovered the inner clutch plate has started to brake up.
cheers Rich
