ECM
I would like to bring you the following under your attention:
On the Dutch GPS board, there is an action going on in regard to the failing routing algorithms in the Zumo (and Nuvi) modells.
When set to "avoid highway's, even other major roads are avoided
In other cases (long distances), if you set "avoid highway's this is completely being ignored, and you can still find yourself on a highway. So this "avoidence" setting is not working properly!!
You are either send over too small roads, or you are directed over highways, even though you don't want to.
Time for some action: PLEASE JOIN US AND SEND GARMIN AN EMAIL ABOUT THIS!
Mail:
[email protected] Subject: Failing NT software
As an example you can paste this tekst into it:
Mail:
Dear Sir/Madam,
I would like to inform abouth a Bug/Feature in the Zumo's software
When the setting Avoiding Highways is active in Europe, not only highways (Interstates called in the Usa), but also the main roads (US-Highways called in the Usa) between city's are avoided. The avoidance is so strong, that only little roads are used in calculation of a route and often we are routed through city centers.
For very few tours this is good, but for secondary road trips from A to B, we only need to avoid real highways (Interstates called in the Usa).
Another problem is that if you plan a long route (+150km) and you set "avoid highway" on; in many occasions, it will still send you over the highway / interstate. So this "avoidence" setting is not working properly in both ways.
Suggestions for a new firmware update:
- Change the avoidancey rules of highways (interstates called in the usa) to exlude avoidance of main roads (US-Highways called in the Usa)
- Change the Avoid Highways in Avoid Interstates and add an extra choice for avoidance of Main Roads (US-Highways called in the Usa), in the Avoidances menu.
- Make these changes work, even over longer routes.
I hope you will take my suggestion in consideration.
kind regards,
*** YOUR NAME ****
