Polak
Have any forum members got this Tank bag? Is it any good?
There is one for sale on ebay and I'm seriously tempted.
The Wunderlich tankbag I bought is a very secure fit, not too big at normal size but when expanded is big enough for a full face helmet. Also, comes with clear protective film to cover the plastic tank area to prevent paint abrasion which seems to be doing the job very well. The bag itself seems very well made with strong zips and stitching. It also seems to be pretty much water proof so far too. All in all, I'm very pleased with it indeed.
got mine from Nippy NormansI used one on an F650GS twin and it seriously marked the paintwork, so make sure you use something like wonderweb underneath to prevent damage. Also it's a bit invasive if you are standing up offroad but if you shift it forward it interferes with the turning circle.
If you like that bag, check out the Bags Connection model that is almost the same as far as specs go, I believe.
I got the Bags Connection one to upgrade from the smaller Recon 11 I was using. It is non-invasive, it zips to the mounting pad and the pad and bag are both easy to remove or just unzip the bag from the mounting pad to take it with you. They provide you with a couple of covers for the bag and two sheets of clear plastic hydrostatic mylar that protects your finish. I went mylar free on my F650 and don't have any issues in 6 months use under widely varying conditions and somewhat lazy approach I have to cleaning my bike.
