Fat Bars
Has anybody fitted renthal fat bars on their HP2? I am after the part number of the ones that will work with the HP2 controls :beerjug:
Yes - will try and look for the number (bike at home today!) ... but I di know that they were the same profile sweep as those fitted on the KTM!!!! They are lower and require risers to bring them to a good height.
BIG DoM
Can you post some pics or a link to pics, lets have a look at this mod:thumb
Hi Chaps, its me again, the man who knew he shouldn't have sold his HP2 to buy a GSA12 which was ginormous it felt even bigger that old 1150Adv....etc...KTM990Adv now its OK even good but aint quite firing the desire as the HP2
Yes FAT BARS HP2, I did it, I bought Renthals as I found the standard bars a bit high rise combined with my lowered seat, I fitted them but they where a bit low so swapped with Maguiras off me Husaberg which were slightly higher, similar to KTM.
Fitting, just needed drill a small 2mm hole for the switchgear locating screws, I fitted fatbars to 1150 and the heated grips where a pain but no such complications with HP2.
They fitted fine, you just need to be careful to get correct angle of bars set plus final aspect of switchgear before drilling the hole for the smal tapping screw to fit in.
When undoing the switchgear you may already know its a fiddly affair with bomb disposal type delicacy and careful to get correct tiny screws out in correct order....I just guessed it and with various bar swaps eventually became well adapted to the rigours?
I will send pix if needed, perhaps PM?
Brgds
simon
