Bendy toy
Much like mine was. If your axle tube is rusting clean it up with a Dremmel or die grinder and get Mikey to have it grit blasted & powder coated before he does the rebuild.
Removed the FD this afternoon. No problems.
Saying bad words about bendy. It was him that encouraged me to remove the 'spade' and have replaced it with a Cymarc extender I picked up on eBay. I'm sure the cuts on my head will all heal eventually.
This is what came out of it. Not supposed to look like that, is it?
I was pretty sure it was changed at the last service about a month ago.
Hi Keith.
Don't know. It came with a Wunderlich kit from Nippy Normans to blank off where the spade was.
TBH the kit really was a farkle. The plate serves no useful purpose and if I had have dug around in my shed, I'm sure I could've found a stainless screw and washer to cut down and fit the hole in the FD casing.
If anyone decides to go for one of those kits, make sure that you run a screw or bolt of the same thread through the holes where the plate is attached to clear any corrosion further into the threads.
The screw that comes with the kit has a small Torx head, plus it's not a great fit.
Going to have fun removing it from the FD if I want to use the blanking plate again.
I see Nippy Norman's selling a kit that moves the number plate on the R nine T to where the spade was. Looks good, but not at £2-300!
Thanks John, I think I'll order the two available guards from Wunderlich anyway, they're only €19.99 each. I'm a little disappointed with the look of the rear hub after removal of the spade.............. it looks very obvious that something has been removed (if that makes sense)Keith. Still had the instructions for the cover.
The screws are dome head and sizes are 2xM6x14 and 1xM6x8. Plus 3 M6 washers. All stainless.
Yeah, hopefully that's the end of the "messy left leg"My bike is a lot less dirty after losing the shovel. Instead of it deflecting crap forwards and out over me the dirt just gets kicked back and away. The fender extender keeps it civilised.![]()
