Yes, I've been using the search, but with so many threads I just wanted to get answers to a few simple questions.
My 1150gs doesn't have ABS but as I read through various threads I'm trying to figure out what the different systems were and their pros and cons, mainly because I'm hoping next year to upgrade to a newer 1150 adventure and I'd like to understand the options.
If I understand it correctly, you can have bikes with no abs, abs and then servo abs. Servo abs seems to be what causes people issues because the servo abs sounds like it has been subject to failure more than the others and that when it does fail it's a 'very bad thing'. When it works, it seems to be fine.
If you 'de-servo' a bike, does that mean you remove the entire abs system or just the servo part. I'm guessing you remove the entire thing and go back to having standard brakes.
Do later 1150 adventure models all have servo abs or is there non-servo abs on some of them?
Is there a timeline for which years had what model brakes fitted?
Thanks for the replies.
