final drive imput seal
fizzer
co durham,england
hi guys i am in the process of replacing the input seal on the final drive on my rockster.
bmw or motorworks do the seal for about nine quid ,but as the genuine seals dont seam to be up to the job is there a better seal to use that others have used to be successful .
many thanks ian
Replace the compression ring as well. It helps.
Part number 33 11 7 701 691
Pekka
:rolleyes:
The seal itself is not the problem, it's the threads on the seal-carrier that weeps.
Give it a smear of sealant and all is good.
Later models (1200??) have an O-ring fitted.
And Pekkavee is right, new seal and new compression seal is mandatory. :D
Paul.
smelly old boots, its got 22000 miles on it ,good tip guys thanks i will change the compresion ring too.
I've done a picture "how to" / it might be in the font of all wisdom section.
yes thankyou steptoe i have had a good read of it,but as said by ian j hartley ,no pictures now,i have got all the right tools on there way to do the job mate ,plus i have a git big snapon imput wrench ,the center nut was so tight i have bent a wheel stud in the vice.
just out of curiosity why have the photos disapeared .
job was done today,let me tell you without the correct tools and a bloody good impact gun dont even attempt the job .
also sealer put round the threads as advised and a new compression ring fitted too.
i will bolt the unit back on the bike tomorrow.
