So a quandry? 180ml enough - or too little in the long run?![]()
Iv used the Castrol syntrax 75/140 £15 from eBay enough to do 5 oil changes Iv just done mine as I'd already removed swingarm to put front shaft gator on,been an 05 I put 190mm but did loose a small amount dribbling out when fillingIv used the Castrol syntrax 75/140 £15 from eBay enough to do 5 oil changes
See link easy to DIY
http://www.mts1200.info/motorcyclei...=contentGeneric.obxaszqugbllbuna&pageId=94625
there are a lot of talks about using 75w90 castrol long life or castrol syntrax limited slip 75w140.
What do you guys use?
Castrol Syntrax is the BMW recommend oil for my '08 and has been used for the life of the bike at 36K. I change it every 6K and have had no issues that I'm aware of.
