First ride on the new bike!
Jonno58
Bristol
So the new bike was delivered Good Friday to my work place where I could fit a couple of Farkles and give a really good treating of ACF50 before any exposure to the elements which I’d always planned on doing.
Circumstances meant it was Tuesday before I could do these so my first chance to ride was Tuesday evening, the anticipation from Friday had been immense, just like seeing presents under the Xmas Tree and having to wait to open them!! It was Dusk when I set off and here are my first impressions of the short thirty miles run that I did.
The GS that I’d test rode had a noticeable ‘clunk’ when engaging first gear and many others have described this trait too, mine doesn’t do this, yet? I say yet because the Dealer has rang me as I’m writing this to see how I’ve gone on and he said don’t judge that until after the 600 mile service and oil change? Anyone experienced this ‘clunk’ appear after first service that makes his comment relevant?
So an unfamiliar bike, brand new tyres, couldn’t accurately read the speedo (my eyesight) all meant I set off riding with extra caution in mind. I needn't have worried.
The torque was amazing. I found I had to be mindful of the change up from second to third using the clutch as I found the front wheel coming up if I ‘overdid’ the throttle. I moved onto using the Gear Shift Assist Pro that seemed to solve this happening for me. I can see this being amazing once I’m really used to the bike and I took to it really quickly. I still preferred using the clutch when changing down from second to first.
Compared to the VFR I’m used to riding I found that on a couple of occasions I was sliding slightly backwards on the seat so I will raise the back bar to see if that helps.
Out of the town and into the country roads and as the ride went on I have to say that the bike just inspired me with confidence and did what asked of it effortlessly. I’ve read people describe that the weight just disappears once in motion and boy they’re right, it proved so easy to handle. Riding a mixture of bends I was soon progressing round them the same as I’d normally ride.
Not being used to having a screen in my line of vision I did find the need to adjust my head angle at times to best judge oncoming traffic correctly though I think this was mainly down to combination of headlights/screen+visor/eyesight ‘affect’. I plan on changing the Standard Screen for a tinted one so maybe more thoughts needed as to what will be best suited. Maybe a prescription one? ☺
A word or two on the lights, I thought at one point someone was coming through on my inside at the first roundabout I encountered then I realised it was just the pitch from the auxiliary lights. “In the sticks” I flicked these on and off a couple of times and they do make a considerable difference on the country roads, Headlight & Main Beam both also very efficient.
Suspension was standard setup and gave a really good ride, I crossed a few temporary surfaces and purposely rode over a few road imperfections and these were all covered with no 'surprise' movements etc, again all re-assuring for a first outing.
Downside? The only thing that was any issue for me was not being able to read the speedo (due to my eyesight). I would much prefer that to be digital and display in the same size font as the gear indicator. I will have a play with the Display settings & Nav 5 as I know you can set it to show on those.
In summary, I have to say overall it was just brilliant and more than the odd ‘yee-hah’ left my lips!! :) I arrived home beaming from ear to ear, knowing I’ve made a great decision to get the bike and wishing my daily commute to work was considerably more than the 5 miles that it is! I’m looking forward to some lengthy ride-outs and as I only used Road Mode trying out the others too.
P.S. as I know it’s Tropical (pardon the pun) for some, a word on the Heated Grips. Very rapid getting to temperature, too warm on the initial two dot setting, if I’d have put finger rolls in my gloves they would have been toasted by the time I got home ☺ so no problems with those!
Thanks again to many of you because reading the reports from this forum has definitely played a big part in making my decision in getting this bike.
Regards Jonno :beerjug:
Nice write up Jonno :thumby:
Can't be easy waiting four days for a first outing on a bike already in your possession - you have way more patience than I do :)
On the 'clunking' - my 2014 GS did it from day one but it isn't overly concerning and it didn't get any worse after the 600 mile service.
Yaaahooooo! yes, the bike does inspire confidence and does bring out the hooligan in some. :D
On the visor, I have a tinted one on my LC. Replaced that briefly with a clear one, and yes, it was disorienting. Got the tinted one back on ... and all is well. I plan to replace this tinted GS visor with a tinted GSA one, if I can lay my hands on a used one.
The speedo is shite ... absolutely shite. Not sure why they could not get a digital one on there. It becomes worse in sunlight, when it reflects everything around you and you cannot see the speedo at all. Dependent on the NAV V for speed readings then on.
Ride safe, ride far.
Good info Jonno
I collected mine last week on wednesday...and had about the same experience :-)
The handling is top! The weight and size isn't intimidating at all.
I'm running the bike at reduced power for the moment (79KW instead of 90KW, 107Hp instead of 125HP)...is a typical Belgian thing...(cheaper to get it on the road).
The 'clunk' is indeed still there...but not always...depends on the speed of the whole 'first gear engaging process'...sometimes.
I use the quick shifter big time...even from 2nd to 1st...(at very low speed).
Not using it from 1st to 2nd...(too rough and bumpy).
Enjoy your new bike!
Congrats on getting out on the bike, you must have been climbing the walls! I don't know if mine has the clunk, as I ALWAYS park in 1st gear, ever since one of my bikes rolled off its sidestand a couple of years ago.
Cheers for feedback & comments guys, comments on screen & 1st Gear parking duly noted! :beerjug:
My new 2015 bike clonks into 1st as expected, but all the other changes are a little sweeter than my 2013 bike - there is a bit less clutch drag than the old bike - but it is still best to blip on down changes and do rapid up changes with just a dip of the clutch to get the sweetest shifts. The LC doesn't really doesn't like lazy up or down changes, part of the reason is that as soon as you come off the throttle the revs drop very rapidly so it takes a bit of practice to match speed, revs and gear accurately but once you have then all is very sweet. I guess the quick shifter attempts to do this for those who struggle to do it themselves ;)
I normally change gear with the quickshifter under hard acceleration, but if I try it riding sedately, and roll off the throttle, even slightly, it doesn't like it. If I'm bimbling though, normal changes with the clutch are smooth, and perfect every time.:thumb
Jonno you can set up the computer display so that the speed is displayed as a digital read out. It's a lot easier to read like that. There was a chap that left a post on how to set up the display. I am sure some kind tosser will post you a link to it. Enjoy your new bike :D
Jonno you can set up the computer display so that the speed is displayed as a digital read out. It's a lot easier to read like that....
Usually I just read my speed on the GPS because it's easy to see and accurate (I have no idea why BMW factors so much optimistic error in the speedometer). But as Dario said you can program your bike to display the speed digitally which will be much easier to read. The ones in the US are particularly bad as they have both scales, 150 mph and 200 kph numbers, crammed on to the tiny little dial and that only utilizes 200 degrees of sweep rather than the typical 300 degrees on a traditional speedometer dial.
Dare I say it. Its in the manual if you read it. I resorted to reading the manual most unbloke like but its actually really easy but fiddley
