That is a result
Next time I want anything I will check with you first
So the connectors are the same as the BMW ones?
Do you guys have them wired so they are always on so relay feed from the dipped beam?? Then say an independent switch for when you want them off??
I ended up getting hold of 2 sets of 10Watt Cree Spotlights - these were a third of the BMW originals in size and about 10 times brighter. Made from Aluminium and they fit the BMW mounts perfectly! The only extra I had to buy was a set of the Male Plugs to cut and convert the Lights themselves so they fit onto the BMW harnass.......... I just did not want to cut the BMW loom..........
The LED lights are now available on eBay - we ended up scrapping the importing due to the fact that a few of the Tossers already sell LED spots and I did not want to tread on toes.... have a looksee at these:
http://www.ebay.co.uk/itm/301203439546?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
they are the same lighst - just different new housing
Unfortunately those lights come with some really stupid DEUTCH plugs........... horrible stuff.... you'd need to get a set of these: http://www.ebay.co.uk/itm/2-H8-H9-H...M&hash=item5af8fdf057&clk_rvr_id=676890813795
What you're trying to get to is the last pic here............ neater job and best of all - without cutting the bike's cables!
Slight mistake, the LED are 10 watt not 18, but are £50 posted, I can get COB lights which are 20 watt, slightly bigger overall but bright, they are £85 a pair posted.
Hi Les, what is the beam pattern of the COB lights? Out of interest what does COB stand for?
So are these both plug and play Les, I already have your HID's fitted on my GSA and would like a brighter spot replacement but I don't want to cut the loom.
Sounds interesting LesGoing to get a plug and play package set up with them, straight onto the GSA plug.
To avoid dazzling others, wire in a pulse width modulated dimmer.
