falcoron
Fitted bar risers the other day and they are the standard 20mm higher and 20mm back. Fitted no problem but 2 things happened after fitting.
1, the ABS wont reset itself after starting and moving off, never an issue before, just keep getting the flashing red lights all the time. Used to engage once riding a few yards and most time after sitting at the lights for example.
2, the throttle is much heavier and will stay in position if i take my hand from the grip. again this never happened before and would return as normal.
Have i did something wrong?
I asked if any mods needed done prior to buying and did the search on here but everyone as far as i can see had no issues.
Any help would be appreciated as im riding in this shite weather everyday
Ron
Ron
