Sooty09
This afternoon I started to fit my riding aids and found very few fit. I use a bar mounted ram system and discovered the bars are bigger than any I have seen before. The U bolts I have available will not go round the bars, one I opened up to suit but its wider than the slots in the ram. GPS mounting aborted with just a small mark on the bars for my efforts.
GPS tapping point, there are two plugs with caps tie wrapped inside the beak. I untied one to see if its a live accessory socket? It has the same 3 pins as the old GS but the very expensive plug from Nippy Normans is a different shape. Perhaps its not the right socket at all.
I have fitted GPS mounts to my last seven bikes without a problem but Im finding this one a bit difficult.
Power is not a problem as I have several Hella plugs and the socket is in a handy location for SatNav as a last resort.
Time to trawl the internet, perhaps a bar clamp ball is the solution, just bet the BMW clamp screw is more than the 8mm Ram ball
