dot250
I have just fitted a pair of PIAA spots thanks to Nick Marshall.
Where do I find the correct place to put the feed wire for the switch so that the lights can only come on if the ignition is ON?
At the moment the switch is powered all the time from the +ve side of the battery & the spots can be switched on at any time by anybody.I am not too good with electrics.
I await words of wisdom?
It was all reading very good until you mentioned the word........Scotchlock!
