- Joined
- Jan 3, 2002
- Messages
- 1,487
- Reaction score
- 8
I've tried this on the R100GS before...and failed
But yesterday I thought I'd practice with renewed vigour ready for the possibilty I may have to do it in anger in not so far future
Using one large lever and a brace of BM ones I got the old tyre off easily enough...lots of meandering along the sidewall before a 'tweak' with big lever thence the old tyre bead was 'free'. A bit of lube was used, 90% washing up liquid . Easy enough. Cleaned rim and lubed.
Took a bit of effort to get the final bit of the bead on for the new tyre - maybe should have left it in the sun a bit longer...but then that wouldn't have worked today
Slapped a load of lube on and tried to get the thing seated on bead on rim each side but not happening...surprise, surprise. No ratchet strap suitable so just basket-balled the wheel a bit to get the tyre spread as much as possible and reached for of those mini gas cannisters. One of the three in a kit you apperently need to inflate after puncture.
I had intened taking out the valve inner first, but forgot, and screwed the canister on. Ping, bead seated
I was somewhat surprised but pleased
Now...maybe it will never ever happen again, but it did this time, so can
I have seen cannisters 3x size of a 'normal' one that should guarantee bead seating - but this excercise proves it can be done without (even if only once?)
Well worth trying when you have the time if you are fancying going of the beaten path.
Always use the compressor rather than a foot pump though. If air is escaping I simply move the tyre accross the rim til it stops leaking. Ratchet strap method is best. But it does help if you have one.
A bloke I know (new rider) had new tyres fitted by a shop who sent him on his way with the tyres still at bead seating pressure 60-70psi
