flywheel puller
garry a
sandridge st albans england
hi i am changing the sprag clutch on my aprilia pegaso 650 and im in need of a flywheel puller if anyone could help me out i would be most gratefull they seem very expensive to only use maybe one time happy to pay postage both ways if not local or if anyone has any good tips to get it off without a puller regards garry
Can you not just screw a bolt into the centre hole of the shaft and give it a good hard smack with a hammer, the fly wheel should jump off with the shock.
Done it a few times on XR's had a oil filter bolter from a 250 wet dream screwed it into the shaft hit it a few times and the fly wheel comes off easy
that will do it a right load of good:blast
so its been finely machined and balanced and you feel the need to smack it one with a hammer cos you cant be arsed to get the correct tool for the job.i bow to your wisdom.:D:D:D:D:D
After information
Hi Garry !! I've just got a f650gs ... Had a load of trouble with it starting ... Done loads of repairs .. Replaced the sprag clutch nd as u say I needed a puller .. However my local m/cycle dealer was helpful nd loaned me 1 :) ..
My question to you .. Is what symptoms did you have to commence your repair ??? I think I've just about sorted mine but any information would be welcome !! Regards turbo
