SURMANATOR
Hi All , any one know how to get a fm radio to work on the bike? i like to listen to radio two,i have a starcom digital and a 550 Zumo so need somthing compatable ?
Pure highway with decent aerial. Use it velcrod to headstock and into an Autocom. Works great and of course its digital so one up on FM (depending on your point of view). Power via a lead mini usb into one of the DIN sockets. Remarkably waterproof too (ish - it needs a squirt of de-watering spray occasionally)
Having done a quick search.... a bundle for around £100/QUOTE]
Hundred quid? I think you'll find £27 is enough:
http://direct.asda.com/ASDA-E80210-Personal-DAB-and-FM-Radio/000506175,default,pd.html
I've got the previous version and its a fab dab. The audio-out lead is the aerial, so no need for anything extra. It'll last 10 hours on a set of re-chargable batteries, and is small enough to velcro to the cross bar - where you can operate the buttons easily (most importantly the "standby" to shut it up when you need to concentrate).
Thanks for that... out of stock, but put it on reminder so to speak.....will that plug straight into the autocom then?Also for something like radio one will it keep going off station when you're moving around ie retune necessary or is it pretty good?
Yep, straight into the autocom.
Nope, it's locked on to the station you've selected - you don't "tune" a DAB radio, you pick a station and that's it anywhere there's coverage.
RDS stands for Radio Data System, and describes the ability to send text (data) on a "sideband" of the main signal - hence you get the name of the station etc.
Gone up to £30 now, but worth a go ... so just ordered one![]()
