Fog light switch GSA
Mr Anderson
Cumbria
Hi, Just noticed my Switch is wonky for the fog lights (2010 GSA), it clicks and turns on but there's play and it can knock off due to the vibes! Can I just buy a replacement switch? of is there an easy fix? Touring in 2 weeks and it will bother me no end if it plays up.
Cheers.
A common problem is the switch failing to switch on. Some folks have solved it with a slip of (thin) plastic packing material under the switch fulcrum.
I did the above to the switch on the missus's gsa, took the switch apart and cut a small piece out of an aerosol can lid and slotted it in the square where the rocker goes into, you'll see what I mean, sorted it out.
Mine is fine but when I have the clutch lever high enough with the bars rotated as I like them, the switch block gets in the way. TBH a standard switch block with bar mounted switch would do the job just as well. (Aux floods are not canbus AFAIK).
