recymechman Guest Mar 21, 2011 #1 one of my fog lights has gone out , its not the bulb as i checked it in the other one , are they fused seperatley? , etc , anyone got any ideas !
WindyChuffer Registered user Joined Mar 9, 2006 Messages 3,866 Reaction score 1 Location Londinium Mar 21, 2011 #2 rtfm mate separate fuses.
recymechman Guest Mar 21, 2011 #3 thanks for your input , i just thought i would ask the question , could do without the sarcasm tho !
(RIP) Miff Well-known member UKGSer Subscriber Joined Apr 18, 2009 Messages 7,978 Reaction score 1 Location The Highest Hill In Norfolk. Mar 21, 2011 #4 recymechman said: could do without the sarcasm tho ! Click to expand... You'll soon get used to it. Sorry.
Ravenbyrne Registered user Joined Sep 17, 2008 Messages 2,734 Reaction score 0 Location Ardee, Co. Louth Mar 21, 2011 #5 recymechman said: one of my fog lights has gone out , its not the bulb as i checked it in the other one , are they fused seperatley? , etc , anyone got any ideas ! Click to expand... Are they factory fitted?? If they are I have no idea if they are on a seperate fuse (Each) But I'll check the manual for ya Chances are its a fuse or a dodgy connection and shouldn't be anything more serious than that, Just checked it and the factory fitted fogs are on their own seperate fuse, it's a 7.5amp fuse. Hope that helps
STUBBS undead Joined Jan 26, 2006 Messages 35,596 Reaction score 3 Location booker, high wycombe. Mar 21, 2011 #6 recymechman said: thanks for your input , i just thought i would ask the question , could do without the sarcasm tho ! Click to expand... best read a few threads then
Sgt Bilco Dream Maker Moderator Moderator Joined Jun 10, 2005 Messages 17,394 Reaction score 1,855 Location Evesham, England Mar 21, 2011 #7 Check the connection at the back of the light. Mine had corroded so resoldered them and all OK now
Beemerman59 Well-known member UKGSer Subscriber Joined Jan 26, 2009 Messages 3,602 Reaction score 37 Location Devizes, Wilts Mar 21, 2011 #8 They are on separate fuses so 2 x 7.5amps. On mine the fuse box is under the beak on the LH side (as you sit on the bike).
claw Well-known member UKGSer Subscriber Joined Apr 25, 2008 Messages 630 Reaction score 88 Location Durham Mar 21, 2011 #9 If you have hid's fitted in the fogs, the fuse should be upped to 10amp
recymechman Guest Mar 23, 2011 #10 thanks for all the help guys , turned out to be the connection at the lower fuse in the fuse box for the fog lights , the wee box had a fair bit of water in it .
WindyChuffer Registered user Joined Mar 9, 2006 Messages 3,866 Reaction score 1 Location Londinium Mar 23, 2011 #11 claw said: If you have hid's fitted in the fogs, the fuse should be upped to 10amp Click to expand... Bollox. Never had my 50W HIDs blow a standard 7.5A fuse. Last I heard, they draw less current than the stock bulbs.
