trotsky
I am looking to replace a set of system cases with something larger and more robust (to handle about three weeks of travelling two-up) and the "What panniers do you use?" thread has been very useful. It's fairly clear that an aluminium case system is the preferred option but I come up against variations on that theme that I'd like some opinions and views on.
There are, I believe, two ways of doing this. The route taken by Metal Mule and the Touratech standard panniers is an "asymmetric" system with a 30-something litre pannier on the exhaust side and a 40ish litre on the other side. The frame holds the smaller, exhaust-side pannier away from the exhaust itself. The second option is the model used by Civil's Cajasahel boxes and the Touratech Sondersystem with two similar sized boxes with an exhaust cut-out and an extension for the exhaust to dump the hot gases out past the back of the box.
I'm not looking for particular advice on which system to choose; if the asymmetric system seems better I'll probably buy Metal Mule and if the exhaust cut-out approach seems more sensible then I'll go talk to Civil - those look like the best option on each side for what I want and what I want to pay out. I'd just like to understand better what the strengths and weaknesses of each alternative is.
What are the advantages and disadvantages of each option? A friend of mine used to design exhaust systems and he was very negative about any modification of the exhaust so I don't know how helpful or even potentially damaging the exhaust extension would be over long periods. Do I need to think about fitting the pannier racks for trips and taking them off when I'm not using the cases, or can I leave them on all the time? I remember at least one thread about heat from the exhaust damaging the frames. How much heat will I absorb through the cut out on a standard exhaust and how careful will I have to be? How much of a pain is the cut-out when it comes to packing compared to the rectangular box internals of the asymmetric system?
Most important - what difference will I see in weight carrying - how many bottles of wine can I carry if I do a quick cross-channel raid down to the Chateaux?
Now come on, be helpful...
