What panniers on your S10?
Bryn
Moderator
Moderator
South Leicestershire
Now I have the bike.... I'll need a set of panniers ( the bike came with the standard Yamaha Top Case but no panniers)
A good place perhaps for a few pics of what you're using... :thumb
:thumb
Quite a few of them are more US market items..... Was hoping for some photo's of stuff available here... such as Ard Cases, Givi Trekkers etc :cool:
Got SW-Motech on mine, pretty decent for the money, I like the quick removal racks which go on and off in about 30 seconds.
I have Holan on mine. Great value, narrow for the capacity as they have an exhaust cut -out. They also look a lot better than some other options.
Matt
www.holan.pl
Quite like the look of the Holan kit....decent price too....Had SWMotech on a previous bike ( i've had a few :blast) good as well:thumb2
The Yamaha kit is neat & tidy with its rails but if you plan on carrying a lot of gear for 2 weeks away then they are basically Shite squared !! plastic faced with light tin alloy shite lock mechanism as well .... but Yamaha say they are only designed to carry weight rated for the bike !! Top box is only useful for a day trip .
Can dig out pics of the SW stuff on my 2011 bike if you want, or if you want to see it on the bike your not too far away for a meet.
ARDcases on s10
Hi Bryn
I can mount to the Holan frames with the cut out no problem at all! I have a set on long term test with Motorcyle Sport and Lesiure magazine this year ! Or a asymetrical set with the Holan frame !
Thanks for all the suggestions once again chaps....:thumb
I've sorted a set .... will report back once I have them in my mitts :cool:
I was offered a set of Hepco and Becker Junior Flash 30 litre boxes and Quick Release frames at a very good price...( ZED 100 on here... nice meeting you Andrew :thumb)
the only issue was that they had come from a 2015 non ES S10, while mine was a 2014 ES model
Having done numerous searches trying to find out if they would fit.. I finally took the plunge and bought the kit :cool:
From what I could find it seemed if there was any issue at all it would be with the plastic cover on the RHS interfering with the fitting of the plate that holds the QR locator hole on the frame. It fits with the use of spacers where the grab rails fix on the bike.
I found that the bits you leave on the bike fit fine, with no issues, including the bit that goes behind the right hand foot peg. Where the non ES has an open space, the ES has the rear suspension cylinder bolted behind it, but it did not affect fitting of the QR brackets.
The issue I had was with the pannier frames themselves... having mounted the top QR's in place, the bottom ones, that attach rear of the foot pegs, were in totally the wrong position. It looked to me like the rear footrest hangers were actually too far out :confused:
Luckily I have a good friend who is quite handy with his TIG welder... and I spent the day at his place yesterday sorting out the 'realignment' of the frames to make them fit.
the right hand side was (relatively) easy , he cut the down tube and then welded it back at the right angle to meet the bracket on the foot peg.
The exhaust side was more of a challenge, as the down tube actually did not seem long enough... He had to cut and attach a 15cm length of solid bar to the lug that holds the QR bolt, and then angle it correctly to meet the down tube.... quite a ball ache.
7 hours of messing about later , a few coats of Red Oxide primer , and top coats of black and they are on the bike and fit :bounce1
The boxes are 38" wide, the same as the handlebars... the right pannier seems to lean out slightly, but not by much , and the frame is in fact vertical...
I've sprayed the panels on the boxes to match the top case colour
The whole exercise has cost me a bit of hassle, and the end result is a set of boxes for a third of the price of an ally set :)
Look Good
Bryn
Good to meet you, dam shame they needed modifying, they do look good on your bike and the silver flash is a good decision.
