Fork oil and paralever bearing tools
PIGGLET
N Yorks/Smoggville
Going to replace my fork seals and fnal drive bearings this afternoon.
Forgot to check what weight fork oil i need :blast Is it 5W:nenau
Also do I need any special tools for the final drive bearings (paralever/pivot and wheel bearing) other than socket set and torque wrenches?
TIA
Pigglet
TIA
Pigglet
FFS Pigglet tell them what model bike you're working on:eek
Otherwise the abuse will fly !!!!!:spitfire :spitfire :spitfire :spitfire
:blast Sorry, been a stressfull day so far, 1100.
Cheers steptoe, There was oil on the fork legs when i got the bike so don't know how long they've been shot for.
Thought i'd drain and re-fill to be sure the level is correct.
Sorry proff :o
Bearings
You will also require a heat gun (screw fix £15.00.) also correct (large) spanners.
Dave gs.
