jaber
thinkin of changing fork oil
1989 r80gs para, how much wot sort etc.
Why do I fukin bother![]()
In all honesty mate,why haven`t you 'fukin bothered' to buy an easily obtainable and not very expensive Haynes Manual for your bike from which you could have found the answer to your question in less time than it would have taken to log on and post your Thread ???
the 'best' oil isn't necessarily the 'recommended in the handbook' oil.....different grades will obviously produce different results......
That depends on how far away his nearest Halfords is - dont it hairy boy?![]()
Now... go back to your polishing duties and have a lie down theres lovely.![]()
JABER..stick 10 grade in each fork..all ok![]()
Mr Farmer Esq. has posted here before( have a search ) of his special mix blend (one fork for compression and one for rebound btw).
Yup all G/s are as stated above..220 for each leg...I use 10 grade as well.
Oh, I have lots of cheap chainlube too!
