What this do mister? Just swapping out a perfectly good air filter for a K&N ( yes I know, but it has to be done!) and on air filter cover there is a sliced in box with booster plug above the air sensor.
Any clues anyone? Be kind
I would attach pic if I could remember how
. I have an adjustable one on my (non Lambda) 1100 running at -10 (ie it fools the ECU into thinking it's 10 degrees cooler than it actually is, so the ECU gives a bit more fuel, richening up the mixture) which gives a lovely smooth feel to the engine, and helps with the surging even before you've done all the things to set the engine up properly.
