Am I also correct in thinking that it retains the current ESA damping setting, rather than automatically switching to Hard when you change to the Dynamic engine map?
Hi Sven - this is fom the handbook Page 92:
Riding mode Selection Enduro PRO (only if coding plug fitted)
For each of the 5 riding modes there is a matching setting for the ABS and ASC systems and for throttle response. With Dynamic ESA OE the adjustment of the Dynamic ESA also depends on the riding mode selected.
ABS and/or ASC can be switched off in each mode: the explanations below invariably apply to the behaviour of the motorcycle with these systems active.
Throttle response: In ENDURO PRO modes: Direct
The rear wheel lift assistant is active in all modes.
In the ENDURO PRO mode, there will be no ABS control at the rear wheel when the footbrake lever is operated. The ABS has been adjusted to offroad operation using studded tyres.
ASC - The front wheel lift assistant is active in all modes. In the ENDURO PRO modes, the ASC is set up for off-road riding.
In the ENDURO PRO modes, the damping variants HARD and SOFT can be selected. Basic setting ENDURO PRO: HARD
