So what would be the symptoms or dangers if itYes, I'm pretty sure you are right.
The dimmensions looks correct and the retaining pin does not have flat ends.
is the bearing retaining pin? Seems to
have been running pretty well so far.
Thanks v4our- looks the most likely suggestion.
Have been looking in Haynes & Clymer , and other possibility could be a
locating dowel on the con rod?
Does the size look right, or is the main bearing retainer bigger?
Inclined to agree with your suggestion though- bit of a big job for me
to replace/renew !
OK - that solves that suggestion!
Maybe get Steve Scriminger to do the necessary
over the winter.
Whoever lost the pin, assuming that it wasn't blown out by excess oil pressure, probably bought and fitted a new one when they couldn't find it.
If the bike is running fine I'd just keep running it.
I stripped an Imp engine once and found three camshaft sprockets in the sump. Feck knows how long they had been in there, but they never did any harm.
I bet there are loads of people riding around with bits in their sumps that they have no idea about.
