Hope someone can help.
Tried to remove the alternator cover yesterday and after removing the crash bars removed all the relevant screws and the cover is loose but It will not slide out past the front shock.
It had a low speed tumble 9 months ago , the fork rubes were very slightly bent but nothing else visible , forks now ok and the front end is back on.
All prev posts on alternator indicate this is not a major job so I am thinking now that the frame has some damage but before I panic and get another headstock are there any reference measurements I can take from the Alternator cover to the front suspension lower mount to see whether my suspicions are correct .
Are there any alternatives or other areas I should look at like the front wishbone before I embark on a full rebuild which I really want to avoid.
Is there anyone local to Cheshire who does frame repairs ???
