Hi . my front brake line splitter weeping , put new copper washers on ( had two goes ) still there its tiny but still weeping , there only an alloy . Im thinking is it cracked , has any one had a similar problem , anyone got a spare .Ta
Previous owner must have had the same problem , it had been apart in the past , so some one else has had a go , why its making me think a crack , goin to have another look tomorrow
Visually the banjo doesn't look to have been tightened. To form a seal the washer deforms under torque. Try refitting the splitter then torquing the banjo to spec (24Nm) and check again for weep - you can remove the union afterwards. Reason to refit it first is so you can apply the torque to banjo
The copper washers were actually diffrent thickness ,they were what i had to hand ,i ordered 20 hell washers so hopefully dont run out .... ��
