The engine front cover of my 1100 is getting past its best and I'd like to try repainting it. As I don't want to faff around with removing it / new seals etc I'm going to try and do it in situ.
If I could ask a bit of advice from those who've been there...
From what I've read on here smooth Hammerite silver is the stuff to use - would a primer help? Or does Hammerite stick ok without a primer? There's one area below the alternator belt cover that's slightly pitted - would a primer help fill the pits?
Removing old paint? Is it best to strip it right back to metal or just remove the loose stuff and feather the edges of the remaining paint?
I've never managed a really good finish with Hammerite smooth - any tricks to getting the best out of it?
And finally, case screws - painting round them / masking them is going to be tricky - how many can you safely remove without causing problems?
thanks
Matt
thanks
Matt
