Front engine case removal
Mort
County Durham
Gails 1100 has a slight weep fron the front engine casing so it needs re-sealing. I know this isn't a five minute job so I'm getting an adult to do this for me but I'm supplying all the parts. I've already bought the main seal in the centre but are there any others that will need replacing or anything else worth replacing while the cover is off?
Cheers for any advice:kissy2
Alternator belt?...
Good opportunity to repaint the front cover if there's any corrosion.
If it's an early one you'll need the seals for the breather pipe.
I could start a Hall Sensor thread...
:hide
yup time to restart the oil thread
:flag
Sarky git
Alternator belt?...
alternator belt, good idea:thumb2
:hide
It's a 99 and don't bother with the thread, it's been done ;)
Thanks for the ideas, I'll look into the breather pipe oil seals.
