malcolmkaty
Hi all
I am looking to repaint the front cover and think it will be better to remove it and get cleaned up and powder coated or painted ,had a look the Haynes manual and looks like you need special tools to fit the crank seal to protech the lip on it ,On other bikes I have had with usd forks you could use thin plastic over the bushes to slide the seals without damage ,I am new to these engines so anybody got hints or tips as the Haynes makes it look a bit of a pain
thanks Malcolm
thanks Malcolm
, paints the proper way to go even if it cost more than powder coat (Which it don't) it is the way to go, and has served me well over the last 40 years!
but there will always be another way to do it, your choice
